Power door locks not working | Ford Explorer Forums
KJThaDon
Michigan
2002 Explorer XLT
All my door locks not longer work with any of the switches. I do notice while pressing the door unlock or lock on my driver door, there is a faint clicking noise that sounds like it's coming from the right rear side...Any ideas? Is there a fuse I should check?
Thanks!
Start with the fuses, then have a look at the primary switches on the driver door.
Do you know which fuses I should check out? Would they all stop working if the driver door one went out?
I would go after the fuses that supply current to the door switches myself. The ones that create a potential difference across the switches when they are open would be the same one.
