Power mirror switch problems fixed…w/o a new switch | Ford Explorer Forums
Kjhadfield
Panama City Beach, FL
02 sport trac 4wd
My problem was my power mirrors wouldn't operate in the right direction and sometimes give issues in other directions as well. On a long list of minor repairs (that I let go unchecked for to long which therefore kept getting longer), this was up next. I had already ruled out a broken wire in the drivers door jam boot, from a previous to-do fix (thanks ncranchero) which then directed me to the switch, for my power mirror problem. At this point, I should of checked with a multi-meter but I haven't learned how to read nor use one just yet (also on a learn to-do list). A replacement cost $35 and if I can tackle the overhead console display fix then I can try and do the same here. So I decided to see how much I could dismantle the switch to take a look around. I decided to pop the switch out of the door panel installed rather than to remove the door panel, either way the switch needs to be popped out (this just saved a step). I opened it up and it did look like the contacts were dirty and corroded so I sprayed it down with crc electronic cleaner, used a cotton swab and toothpick for the tough spots (be gentle on pressure), let dry and hooked it back up. Now I have all directional controls, although I have to put a bit more pressure than I assume you would have to on a new switch but I suspect the contact tabs have slightly bent from usage (if you open it up, play with how it functions and you will see what I mean). So when the problem happens again, I'll try to bend the contacts slightly to avoid buying a new switch.
After I fixed it I did find a good thread/post where ncranchero explains how to check with a multi-meter and problem solve the power mirrors further if this doesn't solve your problem http://www.explorerforum.com/forums/showthread.php?t=259077&highlight=Power+mirror+switch
The contacts on the right half of my switch (with pins to harness side) was the side that was dirty/corroded but I cleaned it all since I had it open
You don't really need to pull apart the right half in the picture (pin the harness side)
