Power Problem | Ford Explorer Forums
Power Problem
brick88
pa
95 EB
I have a 95 Ford explorer EB. It started with the drivers side head lamp not working. Fuses and bulb were fine. It looked like a short. Then some of the dash lights stopped working. Then it seemed to hesitate when in drive. Now, it has lost power. The battery and fuses are fine. When you turn the key it seems to short out. Nothing, no power. It seems like you can hear the relay trip or reset itself. ANY IDEALS?
Sounds like you have a bad connection somewhere, most likely on one of the harnesses. Get some electrical parts cleaner and electrical grease, that should solve the problems.
