Checked my steering fluid and it looks like weak chocolate milk. I've vaccummed the tank out and put new fluid in it 3 times now and it still looks the same. Any idea what's causing this?
Suck all of the old Mercon out of the PS reservoir. Remove the return hose, plug the hole in the reservoir with a rubber vacuum cap. An assistant is handy for the next step. Put a clear bottle under the return hose,start the engine & add Cheap Mercon fluid into the reservoir until it comes out nice & red from the return hose. You can jack the front off the ground & move the steering back & forth while cranking the engine , it wont take long to get the old crap out of the system. Then Pour about 3/4L of a good ,quality Mercon oil into the reservoir,then stop the engine & replace the return hose. Run the engine up to temp , top up the level to the full hot mark. Reservior should now look "Bulls Blood" red & you'll be good for another 5 years or so!
Welcome to this forum! Thanks for adding good information for your first post. The fitting on the P/S pump is fragile, and is known to crack off if the hose is seized on. I didn't want to recommend removing the hose from the pump in post # 2 for this reason. There is a special hose removal tool just for this purpose. It's a squeeze style that expands.
I know what you mean, however it can be overcome by cutting the hose & adding an inline hose connector or a quick disconnect, this can be done safely since the return line does not run at high pressure. I would favor an inline hose connector, since, this is a job done every 2-3 years or so.
Been having the same problem , milky PS fluid, flushed it a few times and refilled with mercon yet it keeps turning milky and it over flows. I am filling up the reservoir to the proper amount after I flush it. Any ideas?
Today during wheeling it got bad to the point where I don't have any steering power until around 1500rpm
