jrjr2u
- December 27, 2008
- Upstate NY near Rochester
- 97 sport
Greets!
I am in process of replacing all the steering lines. They are all off and I installed the pressure hose first. Once in place and tight, the metal will wiggle in the fitting. The fitting is definitely tight. Ok, so I thought this cannot be correct so off comes the hose with thoughts of returning it.
Now I find the directions.... what timing! In them it states that -
This is a first to me. I would really hate to get this all back together and have the lines leak. Can someone confirm that this is true? I will have to get new silicone gaskets for this hose if I use it again but thats ok.
Thanks...
Late model Ford power steering hoses use a Swivel O Ring fitting on the tube ends. When installed properly these fittings are designed to allow the steel tube to move freely in the fitting while maintaining a positive seal. Swivel and or tube movement is NORMAL and does not indicate an undertightened fitting
Thanks...
