mocando
- December 30, 2005
- Valencia, Venezuela
- 97 XLT
Hello People, and Happy New Year.
Couple of weeks ago my fuel pump failed, and also the driver side power window got stuck in the down position. Since I thought it was electrical related I spent a few days investigating the electrical system, checked every fuse and relay. Then the pump was shot. I got my new pump and filter and I can drive, but the window is still down.
All the other windows work, either from the master switch or their switches, but the driver side don't. What seems strange is that the driver side power mirror moves only in one direction, and not four directions as it should.
Also when I push the driver side window switch, to go down, the one push relay clicks, so is getting power. But if I push it to go down, nothing happens.
Do you think it is all a big coincidence and I might be getting a failing motor, along with the pump (weird) or should I check a relay or something else? The relay that clicks when I push the button is deep inside the panel, and I can't reach it.
Many thanks
Many thanks
