The OEM window motors are the best you can get, and they should last the life of the vehicle. Do not replace them ever unless the main shaft bends, or the motor literally burns up. All aftermarket motors are less reliable.
The weak link is built into the drive section of the window motor assemblies, there are plastic gears and "pucks" in there. Those are supposed to protect the motor from damage, thus those "pucks" deform and fail. That is the cause of 99% of window motor non-function symptoms. Those plastic parts are very inexpensive($8) and not that hard to replace.
So remove your old right front motor assembly, and take off the three tiny bolts holding the gear cover on. Inside you probably will find some mess of old crushed plastic pieces. Almost always the three pucks are destroyed, but nothing else is, and you just need those. Take all of the pieces out, the big round plastic gear, and clean it well. Keep debris or harsh chemicals out of the drive shaft area, to keep it from the motor itself. Get some good wheel grease or quality automotive type, it needs to be only filled to about half of the air space inside.
It usually takes 5-10 minutes to figure out how to install the three new pucks with the center section as a group. Set down when you have those parts cleaned and ready, and be patient as you work out how to install it all. I do it in my lap, get comfortable with a few paper towels and the grease, socket etc. R&Ring the motor takes about 10 minutes once you can reach it and all three holes are in the inner metal door skin.
There should be how to threads here many times, it is the same for decades of Fords back to the 1970's.
