Power windows sticking | Ford Explorer Forums
Mike1950
Halifax, PA
2004 Sport trac
All four windows in my '04 stick halfway - it is usually going down but sometimes going up. Driver's window is the worst - I can clearly see it go crooked and then jam up. It will then move with a hand assist and some effort.
Would this be a worn-out regulator, or has the window partially come out of its seat, or....?
Thanks.
I
It could be
Try this first get a can of crc heavy duty silicone spray $5
Spray the tracks
Work it in by going up and down several times
This is a common problem with lots of makes and models
The auto parts store sells a dry lube spray for lubricating the side glass guides. It's not messy, but it's a thin substance so don't expect it to be a permanent repair. The windows on my van are like this, and have been like this for years.
+1 on the silicone spray
Silicone spray fixed mine a couple of months ago.
Thanks everybody. I did try Vaseline, but it's not slick enough apparently. I'll try the spray as suggested.
