pro comp aal | Ford Explorer Forums
pro comp aal
bender
Johnstown PA
'08 Limited
who has feedback about the single add a leaf from pro comp. its listed for $38 at summit. who has it how much lift did it give you. i hear the ride is rough but unless it is ridiculous i dont care. also if you did this and the torsion twist how well does it even out. can the front be jacked up enough to make it level (safely)
I dont have any experience with that brand. It will lift about 2". You can safely raise the front to match but you will need an alignment. I didnt noticed much of a rougher ride with mine but mine is a 94, I dont know if that makes a difference or not. You can find alot of opinions and info on this in the suspension forum.
I had the procomp aal, my axle was sprung over though, and the ride was still very nice, gives about 1 1/2" - 2" of lift
I just ordered the pro comp double add a leafs. how much lift will they give me?
