Problem after front hub replacement | Ford Explorer Forums
charles8998
I replaced the right side front hub about a week ago, thanks to this forum it went pretty smooth. I now notice that intermittently when I press the brakes the peddle is not smooth, Its kinda hard to explain, but its almost like the ABS is kicking in. I am not braking hard at all.It also happens when backing up. Any suggestions?
You may have damaged the ABS sensor, have gotten dirt between it and the hub, or have a bad ABS sensor on your new hub.
