expo5.0
- October 18, 2001
- Red Wing, MN
- 1996 xlt
well, i used a siphon pump thing and pumped out my whole tank of gas (which took like an hour) switched all my plugs to new copper ones (i believe they provide more power than the platinums) and then added five gallons of 92 octane and a thing of fuel injector cleaner, unplugged the battery for a while, and tried to fire it up. it started, but i had a check engine light. i let it run for a while and after about five minutes the light went off and everythings been ok since (the check engine light has come on a couple more times but then gone off in a few minutes each time). so i guess they put something in the gas tank- probably h20 by what happened and i guess there will be no long term damage. anything else i should do? or did i cover it? it does seem to run fine now...
anyways, now comes the fun part. i need to smoke a 5.9 limited with full exhaust, a chip, and an intake this spring when the track opens. this needs to be a sure thing (you guys know how it is) i also need to have a reliable daily driver and all that crap as you all know also.
i've been saving up some money to do a little air ride action in the back and the ps2 crap as well, but i think beating this jeep is going to take priority over everything else. what do you guys think? what will it run?
so what are my options?
1. i can leave it as it is and remove as much weight as i can before i go (but i don't want that to not be enough)
2. I can leave the motor as is, do the air ride and ps2 etc. and see if i win but if i don't drop the rear end down, bump some music and laugh at him because i look way phatter.
3. i can try to find a cheap or used (i know some people are selling them) nitrous kit and run as big a shot as i know won't hurt anything. 75 at the most, but even a 35 shot would probably put me in the clear...
of course i don't know how legal nox is in minnesota and i don't want to get in trouble. i also don't know how cheap i can get a set-up that will give me the desired results.
i don't even know how fast i need to go... what will he run? i have run 15.3 without my baumann installed. how much difference do you guys think a 35 shot would make? how much for the 50 shot? keep in mind that i'm awd and he is 2wd.
please help me out here
