McSlug
- October 22, 2008
- Perth Western Australia
- 98 Explorer
After hearing a mystery noise whilst driving, getting a misfire code and having some performance issues. I started this thread.
http://www.explorerforum.com/forums/showthread.php?p=2466370
The issue remains a mystery even though I have fixed it. I'll explain as follows and hopefully someone can explain to me.
First of all
In my defense as to mistaking a vacuum issue for a stuck in 4wd issue. I took my father for a drive. As he has an uncanny knack for diagnosing any type of car issue. He told me it sounded like a constant misfire and it may have a cracked head or (unconvincingly) it could be a vacuum leak. But there was evidence that disproved constant misfire and other theories. In any case we where mystified and I stuck with vacuum leak as it can cause who knows what, when and where?
As far as not knowing it was in 4wd this is where it gets tricky. I get binding as soon as I turn the wheels on any hard surface when in 4wd. This did not occur and It did not handle any different.
After giving up on the vacuum leak. I played with the 4wd selector switch. I select 4hi, no noise. I select 4lo, grate,crunch,clang 4lo selected. Back to 4hi, click 4hi selected. Back to auto, no noise. Light on dash corresponds to selector switch position.
I pull shift motor. Now the letters I was expecting to see (from pics posted here) was 4L 2H 4H but I had was L N H. I assumed N was 2wd and selected this manually. Fired up the engine, put it in drive, car doesn't move, I rev a bit more, nothing. Go to put it into park, get grinding noise, hmmmm weird. Turn off engine. Deselect N put into H , go to put shift motor back on temporarily, out of alignment. Move selector switch to 4hi, motor fits, bolt it back up, start engine, select auto, drive off, no noise, pedal @ WOT , pedestrians shake their head at hoon flying down the road.
It now drives faultless and shifts from auto to 4hi but I don't quite know what I've really done and what the problem was. I can only think selector shaft was in a "almost there" position causing the noise. I realize I may have realigned my shift motor and it will probably go out if I select 4lo unless I fix it. But WTF is up with the N position and no drive line engagement?
Any clues as to what the issue was would be great.
First of all
