01EB5.0
- November 25, 1999
- Allendale, MI
- 2001 Eddie Bauer V-8 AWD
i have a problem wit my truck on startup after it sat for a few minuts (up to about 10 or so)when I start the truck sometimes the temp. gauge goes all the way into the red...even sometimes past and the check gauge light turns on. the first time this happened I put the truck in reverse and the needle immediatly dropped back down to where it normally sits. The second time it did same. Third time it sat in the red for about 1 1/2 miles...some even at 55MPH. Those 3 instances were last fall, then winter came...had no problems at all...until 2 days ago. We stopped at a rest area along the interstate and I went back to start the truck and the needle got pegged again....backed out put in drive started pulling away and it dropped real fast like it had before. Since then it has done it 2 more times. The thing that confuses me is why the needle just sits in the red (Or past it) for up to 1 1/2-2 miles and then it'll just drop in an instant back to where it normally is. WHat may help figure out the cause of the problem? I just replaced the T-stat and coolant 4K ago and replaced the radiator cap also. Please help!
