Problems Replacing Motor Mounts | Ford Explorer Forums
rangerguy94
Hanover PA
1994 Ford Ranger XLT
Ok im replacing the motor mounts on my Ranger its a 3.0 i got the passanger side mount replaced no problem but the drivers side is a different story. On the drivers side i got the top bolt off but i cant get to the bottom bolt at all there is no possible way to get a socket in there is there any suggestions on how i can get this bolt off? because the drivers side motor mount is broken completly thanks!
on my 94 ranger I had to unbolt the lower motor mount bracket from the frame with the mount on it. Then switch the mount and reinstall the assembly. Not to hard but ABS control sort of in the way. Hope that helps.
