nessa
- March 27, 2007
- 99 ranger
I have a 99 Ranger v6 4.0. Thanks to some great help from you vets I was able to tackle my first problem a few months ago and replace my very own clockspring. YAY ME! Now I'm having another issue and hoping I can get some guidance here on tackling it. I noticed some weird hesitation when I drove a couple weeks ago. It wasn't constant and just felt like I was going to run out of gas or something but then it would go away. The truck never died or got loud and jerky or anything. I pulled the code and got P1450. Then a couple days ago I went to pull the code again to double check it so I could come here and look it up and I got the same P1450 but now also a P0306. I've just replaced the gas cap and had the fuel filter replaced last week crossing my fingers that it was something small and not too involved but sadly that didn't fix it. The fuses and relays are all good. I have the Haynes manual and tried to listen for the pump like it tells you in the early diagnosis stages but I live alone and have no "assistant" to turn the key for me to listen to it start up so I can only listen while it's running and I have no idea what I'm listening for. Is it a very loud sound? Will it be super obvious when it happens? I hear a whirring sound when I put my ear to the spot where I take the gas cap off but I don't know if that's the pump or just the sound of the truck running. I have no idea how to tell. So I don't know what to try next. I'm hoping someone out there knows what the code means and what the likely causes are. I'm trying not to drive it so I don't make it worse. It never has died or failed to start but I'd like to get it fixed for a long drive I need to make next week. Any help would be HUGELY appreciated.
Thanks!
Venessa
Thanks!
Venessa
