Problems with my Ford Explorer 92 4x4 control i dont have solution (with pics) | Ford Explorer Forums
Popochoclos
Explorer 92 XLT
Hi everybody, this day I did fixed my 4x4 shift motor, i changed the arness and use copless (I love that color :)) well, I disassembly motor and checked on battery and run's perfectly, ok I put the motor in his place and I in to car and I looked the control dont turn off LOW RANGE (LOW RANGE Led turns on ever ever ever and don't off only shutting down car, this problem was after the fix) and don't turn off, ok i checked with my prover and...
check my photos
I checked with my prover and this cable turn light very strong
I bridged a led of Low range and one point and led turn a powerful light and turn on the 4x4
What is it ?
don't short stuff to see what happens.
if you haven't checked for blown fuses yet, check all the fuses..
i had a problem with my 4x4 (wouldn't go into low range, but would go between 2hi and 4hi) and i ended up just swapping out the transfercase (And shift motor) with a spare i had.. worked fine after the switch.
also, if you're neutral safety switch is messed up it will prevent it from shifting in and out of low range. try starting you're engine with the shifter in gear and see what happens (if it starts in gear neutral safety switch is messed up)
