Proper High side & Low side pressures? | Ford Explorer Forums
PDA1
PA
'96 XLT
Year: 1996
Make: Ford
Model: Explorer
Engine Size: 4.0
Refrigerant Type: R-134a
Ambient Temp: 65
Pressure Low: 45
Pressure High: 140
I just replaced the compressor, orifice and dryer on my Explorer. Naturally, I flushed the system out.
I put in 24oz of R-134a. (there is supposed to be 26oz in the system....I wish those cans had more than 12 oz in them!)
The a/c system cools very nicely.....so far.
Do you think my pressures are good?
Do you think I should add more R-134a?
Can anyone direct me to a chart for proper Hi/Lo pressures on a 96 Ford Explorer 4.0L ?
Thanks for the help.
I "think" its a "little" low. I always use 2x + 50% of ambient temp to figure the high side pressure.. If its 65F out then the high side should be 160ish.
BUT..
If it cools enough for the climate your in then its fine. Better to be slightly under than over charged.
Also, I'm assuming you don't have a VOR (variable orifice tube). Those will give you higher idle readings as their job is to increase the pressure differential at idle.
~Mark
The text says nothing about it being a variable one and since those cost more I'm pretty sure you didn't get one. Most places don't even know they exist.
You usually only see them used in really hot climates..
~Mark
Taken from the Haynes Book.......
Note: The following pressure specs are for systems in good operating condition, at sea level and (unless otherwise noted) at an ambient temp of 80 degrees F.
'95 (and '96) Ford Explorer
Automatic Systems
Low side 20-50
High side 160-250
Manual Systems
Low side 22-50
High side 160-250
HTH.
Aloha, Mark
PS..........since you asked about the clutch cycling in your other posts.......
In the Haynes book there is a troubleshooting/comparison chart (for the Ford Fixed Orifice Tube system). I suggest that you buy the book, as there are specific test conditions that need to be considered.
