Put SeaFoam Deep Creep into My 5.0 | Ford Explorer Forums
smiley1
central coast, Ca
1998 XLT V8 AWD
I brought the truck to operating temp and shut it off. I removed the intake tupe at the TB and sprayed the crap out of it while manipulating the butterfly.
I then let is soak for a few then started up the engine. It smoked a little but not much. I sprayed the DC into the brake booster line and got lots of smoke. After about 2/3's of a can went in I quickly shut it off and waited for 10 minutes. I took for a spirited drive. I think my neighbors thought I broke my truck. It was kind of funny. Smoked for a good 2 miles then it started to subside.
I dont know if I gained anything. Idles the same (good as always) and power is the same as far as I can tell. MPG will be calculated later. I just dont think my truck realy needed this treatment. Oh well, it didnt hurt.
I thought I had read somewhere that one should not spray any type of cleaner into the throttle body, that it would damage the electronics.?? I really don't know. I use SeaFoam on my outboard all the time, but it is carbed.
Smiley, let us know how it turns out. I also posted on another entry about Seafoam Insertation point. Would be great to know what is the right way of doing it.
I did not shoot the Mass Air flow sensor. I think thats what people are taking about. No problems at all. Ill keep you posted.
Where is the Mass Air flow sensor located?
Its bolted to the air box with a rubber tube that extends to the throttle body. I just undid the hose at the throttle body so I wouldnt mess with the mass air sensor.
OK, Then it is before the throttle body after the air intake filter? I should be able to locate that.
