question about my rear axle... | Ford Explorer Forums
expobronc
Hayward, MN
98 V8
okay heres the scoop. during left hand corners my explorer spins the left wheel really easy under realitivly light accleration. during right hand turns it barely chirps.
I am wondering does this sound like a problem with my limited slip?? ive already checked the brakes for uneven pressure or something there. but also i just read that incorect toe in could cause this, which means a bent axle. but how hard is it to bend an 8.8?? a year or so ago i was rear-ended and it bent my frame a little, could that cause some of this? or would that just make the truck track a little funny? i dont think the bend in the frame is near the leaf mounts. thanks in advance guys
- J -
:chug:
Incorrect toe will cause the front tires to chirp under cornerring, but I have never heard of this happening on the rear. From your discription is sounds more to me like you have a posi going weak on the right side.
good thats cheaper/easier to fix :) thanks!!!
