Adam Berger
- May 15, 2002
- Melbourne, Australia
- 1999 XLT 4wd
I have been reading a past thread relating to auto gearbox problems with slipping and no engine braking and the fix involving replacing gaskets. I would like to ask those who have had this problem whether what I am about to describe seems like the same problem, here goes:
I did a service on my Ex at 100,000km (60,000miles), part of this included changing the tranny fluid on my 5 speed auto. I dropped the pan, replaced the filter and filled it back up with new Penrite synthetic ATF. When I started it and put it into drive, it slipped like hell until the new fluid circulated around. After this it continued to slip, so I checked the fluid level and put more in. I then took the car for a long drive to my dad's house. When I got there I checked the level and topped it up as it had dropped.
The next day, I reversed out of my driveway, and it slipped after putting it into drive and it sat there for about 5-10 seconds with the revs climbing until it finally took off. This has been happening for weeks, meanwhile constantly checking the fluid level. I left it incase there was any air trapped in the gearbox. It still hasn't gone away.
Today I took the car for a drive after putting a fraction more fluid in (the auto shop suggested to put a little bit more in) and it did the slip thing as normal. Mind you, the fluid level is now over full so it can't be low. After my long drive today, I pulled into town off the freeway and the gearbox just started slipping while doing 60km/h (37mph). The tacho started climbing and dropping on its own without me altering the pedal and it would keep on doing. It is almost like it is shifting in and out of a lower gear.
After I left town this evening and accelerated to freeway speed, it slipped like hell again and had no power at all. After I got home, I checked the fluid which was still overfull and I jumped on this site and did a search where I found that a broken gasket can cause slipping. The gearbox was absolutely perfect before the oil change. I wonder if by changing the fluid, it cleaned out the gearbox of gunk and opened gaps in the gaskets and by now having too much fluid has caused the gasket to blow out today? I've heard that too much oil causes high oil pressure in the gearbox.
I am keen on replacing the gaskets mentioned in a previous post but would like to get other peoples opinions first.
