Question on installing LED bulbs... | Ford Explorer Forums
Afboy143
Tampa,FL
1999 Ford Explorer Sport
http://superlumination.com/194.htm
If I wanted to install the very top LED bulbs that are white in my truck, would this create a problem? I want to replace all the interior dome lights with it, and the 2 outside puddle lights. Would I need a load equalizer or would it just work fine?
Load resistor is only required for bulbs on the buld out monitoring circuit. As long as you buy LED bulbs for a 12V system they should already have a dropper resistor built in. Or you could buy some white LED's on E-bay and make you own bulbs if you know how to do it.
