No, it is easy. Assuming you can change oil. Unbolt leaf springs, shocks, sensors, brakelines, and driveshaft. Sounds like a lot, but really goes fast.
a bent rear axle....as in you bent an 8.8"...thats impresize....but its not that chalenging, pull the drice shaft(just disconnect it form the pumpkin) then the u-bolts, spring plates, shocks and brake lines.
