Creager
- October 11, 2004
- Charlotte, NC
- '92 Sport 4x4
My ps pump was shot (it had been leaking around the pressure hose for a little while), and i have been driving around with manual steering for about a month now. Finally the pump locked up last friday, totaly seizing the belt train, leaving me stranded not but 3 miles from my home. about a half mile from my girlfriends house, No biggie.
I bought all the parts saturday, took it easy sunday, and monday i decided to start the job.
Today i replaced my power steering pump and pully. It was a relativly easy task, except the tool napa loaned me didnt just seem 'durable' enough for the job.
I removed the old pully fine, no problem there. But when i went to go installed the new pully on the new pump, the small intermeditate screw (which screwed into the pully shaft, and held the cork screw on) kept breaking, in half, long ways.
I made sure to keep the end of the cork screw (1/2 box wrench) and the pully (oldBelt + vice grips) from turning while i torqued the nut, because thats the only way i could think of that would made it break. That little screw just couldnt hold up to the torque i HAD to put on that cork screw to press that pump on. Ball park, 200-400ftlbs of torque.
After the first screw broke in half i tried to keep in mind to loosen that screw up after a couple turns. That helped but again i broke another one.
At this point i was freaking out because the 'pully press kit' that came with the reman'd pump also failed (that thing was WAY to small to ever press that pully on... I warped the NUT!)... And i had pretty much destroyed this Kit from napa... But! The best part about is the fact i pressed the pully on BEFORE i put it in the bracket on the engine... hrmm... when it doubt read the directions? hehe oops..
i was able to pull the new pully off with out a problem (or i mean i fixed my MAJOR, PAIN IN THE ASS, boo boo pretty easily). Then I attached the pump to the bracket and proceed to once again venture into that crap. So this time i use BEARING greese to help aid operation, good idea? Yeah i thought so for about 20 minutes. My last screw was holding up great; i got that pully about half way on and.. oh ohoh SNAP.
This point i wasnt even thinking. I grabbed one of the longer screws that snapped, sawed the broken head off of it and used it to assist in getting the pully the rest of the way on (i got lucky in the sense that the pump shaft and the cork screw 'tool' had the same size inner threads). It worked. damn right, i got i got the whole thing buttoned up in 20 minutes from there, i had to go watch some fireworks...
But now im stuck with this KIT that is destroyed because it was in no way suited for the job... NAPA probably isnt going to take it back... Any ideas? I can make that $95 bucks go a lot further then my trash can
