Mitchs07explorer
- August 14, 2015
- Location
- Idaho
- Meridian, Idaho
- 97 XLT V8 AWD
07 XLT V6
Okay, I replaced my front left hub a few weeks back and the job went smoothly. Lately I'm hearing a whirring noise that sounds more like A/T tire noise but I swear it's getting louder just like when my front left went bad. I lifted the SUV up and went around and spun all my tires. I'm pretty darn sure my rear left hub is going out now. There's definitely more of a grinding noise when I spin that one. One of my questions is about the front left hub that I already replaced, its smooth when I spin it but it also faintly sounds like there is a rubbing/dragging noise, very light noise (speed sensor maybe!?) when turned one full rotation. When I go around to the other two "assumed good" hubs and spin the wheels they all sound about the same as the new one. The only real difference is the hubs with 104k on them roll easier than the new Timken I installed. The new one has a little more resistance when turned than the two older hubs but the older hubs have that faint drag feeling when you turn them too. So I assume that's all normal?! Can anyone tell me what that is? Is there a speed sensor or the abs sensor that I'm noticing make a slight noise when I spin the wheel a full rotation?
Also can someone recommend a good quality precision torque wrench or tell me if the one I'm using is okay. When I replaced my front left hub I used a 25lb-250lb click style wrench by EPAuto. It was only $50 on amazon but it had nearly a 5 star rating. It says it's been properly tested and calibrated and will guarantee a +/- 4%. In my opinion a +/- 4% seems like a wide variance to me especially when torquing the front axel nut to 184 pounds. That would mean it could be as tight as 192 pounds and as loose as 176 pounds. This makes me paranoid because if the axel nut is not in the right tolerance range the bearing can go bad in under 5000 miles. I'm wondering if I went to cheap on my torque wrench. Yet I found an OTC torque wrench that was $200 and it gave the same +/- 4% variance. That leads me to believe that the more expensive wrenches are more for professional day to day use versus the DIY guy in their garage. Does anyone know about torque wrenches, did I make a mistake by not buying an expensive name brand wrench?
I apologize for the newbie questions, I don't have a lot of automotive experience but I'm fairly technical and like a good challenge. If anyone had any info to offer it would be much appreciated. Thank you!
