JT624
- May 17, 2007
- Providence, RI
- 2000 XLT
I've been having a lot of overheating issues lately. Initially I had a leaking radiator, I knew of it for a long time but let it go and just kept topping up as needed. It wasn't a fast leak but I knew about it. A couple of months ago my girl had the truck on the highway and it gave out, completely overheated (I know. the phone call you never want to get).
After a tow home I changed the radiator the radiator cap, and t-stat and flushed the heater core and block with water from the hose for a good 45 minutes or more (I didn't use any special flush as it was constantly being topped up it ran clear almost immediately). Anyhow, after all of this I am having the dreaded overheating back for a second visit. Now it overheats as soon as it warms up, mostly under load or if I revv the motor in the driveway (I've been doing that while looking for leaks).
So long story short: I believe my fan clutch is no good. It has the same loose frewheel to it whether hot or cold. My question is: How much does the fan speed really affect the temp (gauge)? I'd hate to change it if I'm overlooking something but apart from the water pump or a dead mouse pluggin a line (neither seem to be the issue) I don't see what else it could be.
Thanks in advance for any opinions you folks can offer.
