quick wiring question... | Ford Explorer Forums
brian r
the three wires coming off the 4x4 shift actuator that go to the t-case, do they all have to be cut? i know the brown one does, but what about the other two that go to that little switch? does that unplug? any info would be appreciated.
Wires...
I think the 2 other wires that you are talking about should be blue and green. Yes it unplug, just twist/pull the black base where the 2 wires go in, it basically is a magnet to retain metal shaves. For the brown wire I cut it and put a connector between the 2 parts, so next time I just have to the wire appart. If you need other info write back.
