Radiator fans won't come on | Ford Explorer Forums
Cam Cornelius
Location
Nashville, TN
Nashville
2014 PIU
2010 CVPI
Callsign
K1CAM
Just discovered that both radiator fan one and two have an issue in my 2014 PIU. I'm pulling codes P0480 & P0481. I've replaced the related fuses and relays in the fuse box under the hood...still no dice. Is there another fan control module or something I should be looking to replace or test on the canbus or under the hood? Both fans are showing a fault when looking at them in the dashboard in Forscan as well. Unpowered, they spin freely, so the bearings seem good. I find it kind of strange that both have failed, but then again I'm new to explorer (been a Crown Vic guy since about 95).
P0480 is cooling fan #1 and P0482 is cooling fan #2. Error Code P0480 is defined as Cooling Fan 1 Control Circuit Malfunction. This code refers to the engine cooling fan circuit as it experiences a malfunction, causing the fan to fail and allowing the engine to overheat. Same for #2.
https://autoservicecosts.com/obd2-codes/p0480/
