G
geoph1986
Fuel pump won't come on...Update
My truck has been sitting for a few months, because the front end got too much play and was getting scary. The battery has been disconnected the whole time. I finally got all the front end stuff done and went to start it and the fuel pump won't come on. I checked all the fuses (both under the dash and in the power distribution box), tried swapping relays and bypassed the inertia switch with a jumper. It seems that I'm not getting power to the rear of the truck. However, I did have minor success as the pump will run if I connect power directly to it. The truck was running fine when I parked it and now nothing. :scratch:Any ideas? I'm sure this is a simple fix that I'm not seeing, and I did use the search button. I guess the OBA will have to wait until this issue is sorted. Thanks for any and all help.
