mark.s
- November 18, 2013
- Florida
- Ford 1993 Explorer
My 93 had issue with the random engine stop with no warning sign. After shut-down, it restarts just fine and runs fine.
Changed the fuel pump along with the filter, thinking it is shutting down randomly since it is old. But it didn't solve the problem. :thumbdwn:
ECU was checked visually. Couple of capacitors were leaking and printed board had missing line. I fixed all of that. But, still the problem persists. :thumbdwn:
CEL is coming on, so I pull the code. It was something to do with O2 sensor on one bank. I did not think changing O2 sensor would solve the problem. The truck runs fine when it is running. But I changed both sides anyways. This didn't do squat. CEL still comes on and engine stops at random. :thumbdwn:
Talking to a friend and I decided to change the fuel pump relay. And, this did the trick. There's no more shut-down.
Cut open the old relay to see what was happening. The points were badly eroded.
I think I will be changing relays when I can as a preventive maintenance.
