ranger clutch | Ford Explorer Forums
ranger clutch
barnsey52
2001 ranger
I have a 2001 ranger and every once in a while the clutch pedal goes about half way and releases just off the floor. Then after a day or two it gradually returns to full pedal and works normally. Had slave cyl. replaced about 30,000 miles ago.
You may want to bleed the system again, it is hard bleeding the air completely out of this system. Although, I was told to use the vacuum type bleeder.
