Ranger Crank,Crank and finally starts | Ford Explorer Forums
2006R
2006 Ford Ranger
Hello, my 2006 ranger will not start until you crank it for a long time.What I now do after reading the forums is turn the key to the on position 2-3 times to cycle the fuel pump.This is to build the pressure up and then the truck starts well.
I am planning on installing a one way check valve to keep the pressure high, the check valve is only $14
http://www.ebay.com/itm/One-Way-Fue...Parts_Accessories&hash=item2a293b8be2&vxp=mtr
But my question is does anyone have any idea what size the fuel line is on a 2006 Ranger?This check valve is for 5/16 hose
..Perhaps it's just a dirty fuel filter or a fuel pump that's getting tired and will be needing replacing..
..I'm not sure then why you would put a check valve in before you remedy the problem..:dunno:
there is already a check valve in the fuel pump module. a replacement module is the proper fix
my 91 does this, i dont see it hurting anything to crank it for a few seconds, i tried the "cycle fuel pump" thing once. it flooded, then i didnt let it "unflood" all teh way and finally got it started and it started so hard 3 vaccum hoses blew off. havent tried it since lol...
