Rx4phun
- December 1, 2001
- USA
- 1998 XLT SOHC
Can this be done without too much problem? Ideally what I would like is to use a cutout flare on the front of my X to make room and cover the tire that is sand blasting my paint job now. The issue with that is I would not be able to get a flare that looks just like it for the rear.
So I was thinking of just putting an extend-a-flare on the front from a ranger and the same design and color on the rear from a explorer. THe reason I was thinking front from a ranger is because I think they have larger front fender openings. If I am correct in saying htis it wojuld allow me to use them as a cutout flare on the X.
The main goals that must be accomplished by this are (1) I need to make room for the 33s so they dont rub at all, which they do on the sheet metal in the front. (2) to cover the tires completely so all of the road gunk stays off of the X. New England winters beat the hell out the paint job even with out tires that stick out 3" and (3) I need it to look decent, which means I can ahve different fender flares in the front and back.
Thank you in advance for you help and yes I have searched and searched, any and all suggestions are welcome (except fiberglass because it wont meet goal #2).
Gary
Gary
