AMMO_HOOAH said:
Good info, that's what I figured, but when I saw the listing for the explorer I had to ask. When you refer to the center axle disco you're refering to the 4X4 V6 not the AWD V8 correct? I am planning on swapping the AWD (4404) out for either the 4406 (already proven to work fully) or the 4407 if it'll work. In either case I'll have a fully disengageable front end. Are the manual hub options the same for the AWD that you spoke of, and is it as easy as it sounds or a major pain? Thanks for the help.
AACK!! I missed the V-8 AWD in your sig....
The AWD and V-8 use a live front axle.
I'm not familiar with the 44-07.... selectable? I just skimmed your other post on the issue, but wasn't really paying attention to any of it.
Also, I may be mistaken about the hub setup.... I think they didn't go to the PVH hubs until '01 or '02. IIRC, the 97-00 Rangers used the *old* automatic hubs like the first-gen Explorers. I don't remember when the Ranger ditched the TTB and went to the SLA front ends, or whether or not the auto hubs crossed over before or after the suspension change.... it's all a little fuzzy at the moment.
So, yes, if you swapped out a selectable transfer case, and could somehow manage to adapt the Ranger front drivetrain components, then yes, in theory, you would have a selectable front end.
Now, that being said, line up a v-8 with low range, and you'll start eating CV joints on the front end for lunch! They won't hold up to the V-6, let alone a V-8 with tall tires and low gears! Start looking at front axle upgrades.
-Joe
