2013 Pearl
- August 9, 2020
- Peoria, arizona
- 2013 Explorer Limited 2.0
Smelling raw gas fumes in the cab while running AC or Heater. If on the recirculation setting it is better, but still there. Started last spring and is at it's worse now. On occasion I can smell gas outside when I get out of the rig after driving it. I searched all over with eyes and nose and cannot find a leak from tank to pump and at the fuel rail and injectors. The smell is strongest on the passenger side under the hood but not strong enough to pin point it. Seems to be most obvious with a cold start. Owned since new. Up to date with all recalls, seviced regularly and all common issues have been addressed.
Here is what I have done so far.
Dealership A diagnosed the upper PCV hose, which is common. I am not smelling a crank case smell...but I replaced it anyway since it was leaking oil. Not fixed...
Called FoMoCo and they recommended going to another dealership and opened a case for me. Dealership B diagnosed a bad injector seal, oil separator, timing cover reseal and valve cover gasket. I was a 63B in the Army so DIY when I can. I ordered OEM parts and replaced these myself. I did not do the valve cover since it was not leaking and the timing cover was done under warranty prior and not leaking bad enough for me to take that job on. I did the injectors and oil separator. I did not notice any sign of fuel leaks at the injectors but the oil separator was indeed leaking really bad. I blew the case with Ford since I did the repairs myself but could not stomach the estimate. Not fixed.....
Months later to date and not driving the rig due to the gas fumes and concern for safety. We have dumped too much into this car for maintenance and prefer to repair it and keep it, but I am stumped on what to look at next. Hoping someone may have a similar experience and solved the problem? Thank you kindly.
