RAWR!! It's getting really bad. | Ford Explorer Forums
Vanquish502
Kitchener, Ontario
91EB, 91EB, 92XLT
A while back I flooded the engine, and it's never ran the same since.
It started out as a misfire, then turned into stumbling, then a stall here or there...
There were times it would run perfect until it was shut off, then start it back up and sputter and misfire...
Now...it never runs right. Sitting at a light, you can feel 2 or 3 cylinders miss until mid-RPM range. You can hear it misfire when you try to start it.
What the hell is wrong?????? I've been searching for 15 minutes...
sounds liek an electrical problem more than anything... you probably fried a sensor or the coil pack.....
Coil pack is located where? Searching is showing nothing...
Searching seems rather useless on this forum sometimes... :/
