RobAtPace
- August 22, 2000
- SiNY... NYC
- '92 exploder sport
hey guys... (and girls)... i have been a member of the online 4x4 community for a few years (owned my explorer for over 6 years...)
basically my story...
going thru the baja's of tottenville (in staten island, NY) and unfortuneatly flash flooding happens (the weekend of 3+ feet of snow melting via 3 inches of falling rain)...
no problems treading thru 8-12 inches of flood bc i am abit higher then normal explorers... as i proceed i see more water... looked about 8 inches or so -- it was a paved road... WRONG!!
as i begin my drive thru it, i suddenly notice the pitch of the road is getting freakin ridiculous... no more then 6-8 feet of treading thru the water, i realized i needed a captains licesne... my front bumper was sumerged, and the water was upto my door sills... i quickly debate backing up, but the change in throttle might stall me in the flood waters...
SLURP ... engine stalls.. she wont start since the lovely starter is sumerged.
i had to do a dukes of hazard and slide out my windows bc i didnt want run off pouring into my truck... i am f*cked... i am 6'4 260 pounds... fitting thru this window (with rain guards, making it even smaller).
i land into the water, thigh high... has to be like 3.5 - 4 feet worth of it... i pushed the truck to safty... said a prayer... turned the key... nothing... starter was soaked as was everything else...
i wait hours, finally giving up and locking her up and walking .5 mile thru other flooded streets to my house...
i go back sunday (day later) and dismantle the air box and check out what that SLURP was... yep... my engine slurped some water...
the filter was soaked, the tube with connects the air box to the engine was nice and wet still... i smirk, walk back to my (parents) honda oddessy and drive back home...
i do some research and realize that i should also check out my oil and tranny stick for ***** and giggles... yep, fluid levels are abit higher and runnier... F*CK #2...
i call AAA to get it towed back home, i call my friends pop, a NYC mechanic and tell him my story... he laughs and says not to worry...
remove the distributor cap... the spark plugs...
drop the oil pan and drain and change all the fluids...
get some dry gas incase water got to your fuel lines...
dry out the starter and maybe try to find a junked explorer and pull a starter from that one just for a temporary starter to see if the engine works... (i suppose his humor in it is why drop 130 bucks for a rebuilt starter when the engine could have been toasted...)
leave the truck opened up for a day or two to let it drip and air dry...
say a prayer and put her back together....
my question to you guys... any recommendations?
any previous encounters with thirsty engines?
what did you guys do?
i also read about the differntials and the vent houses... i will take a look into that as well...
thanks... pray for the exploder... an excellent truck until mother nature decided to screw around with me...
