re-use flexplate to A4LD torque converter nuts? | Ford Explorer Forums
saxon
seattle, wa
'91 & '93 EB, 4WD, 4-door
The Haynes manual doesn't say that they cannot be re-used but this posting does: http://www.explorerforum.com/forums/showpost.php?p=1133071&postcount=4. Well, I think the Haynes manual doesn't say that; I'm not at home and I can't find my extra manual.
So what's the scoop? If I loctite the nuts and if I am able to get a torque wrench in there (questionable) can I re-use those nuts?
If I cannot re-use them is anyone likely to sell them other than Ford?
Installing used A4LD from 1993 EB 4WD into my 1991 EB 4WD.
Ive always reused the tc bolts just make sure you loctite them you will be ok.
