jakedrew
- August 9, 2009
- wisconsin
- 04 xlt
Dont know why I read up on that site, but I do. http://www.carcomplaints.com/
Some usefull info on there about common issues.
My problem is I read up on there and I get paranoid about reading all these problems with the explorer.
Let me run down my history with my bought brand new 04 xlt v8.
3k miles nail in tire( I know nothing major)
10k miles- transmission additive added for harsh shifts, CEL= computer needed to be reflashed. and new stereo installed ( had to press the seek button twice to make it switch)
25k- water pump started leaking. Replaced water pump.
(SHOP did a half as$ install and went back in the next day for a new belt that replaced the shreadded one on there which caused a chirping 25k miles later, i had to pick rubber off the pulleys).
33k limited slip in rear end wasnt disengaging. - New rear end.(just had to do with the limited slip/ not the howl)
37k- shifter had a hard time moving out of park- new solonoid part.
43k front sway bar bushings ( i did)
46k - heater worked on High only ( i replaced the 1234 dail behind the knob)
48k - ABS light on- I replaced the rear end speed sensor.
50k new tires
53k Rear end howl - Extended warranty covered the rear end TSB.
55k new battery
56k Front diff input shaft seal was leaking , /extended warranty
loose steering wheel feeling over bumps/ upper steering shaft replaced
62k Blend door actuator ( i replaced )
I am just out of extended warranty so I am on my own from here on out. I dont have a problem wrenching and these forums are awesome and saved me a ton and gave me some great knowledge.
63k Now I need a left front wheel bearing and I parked it for the summer an drive my 02 cavalier (which i dont drive in winter).
My complaint is I think I HAD my fair share of issues. I am not a ford guy really, I got a 94 taurus off my grandpa which I put a ton on miles on and it still runs great. Just did a tune up at 150k and that was it.. So I figured a 36k $ ford would be just as good.
I like the explorer, looks nice, rides nice. I can tow stuff. I have it undercoated, windows tinted and f150 tow hooks( love the way the look), bug shield , and the ford rear roof wing.
I am just about payed off on it. ( got the 72 months at 0 % as i knew i would keep it).
Part of me wants to get rid of it after reading all these problems. But I got most of the bugs worked out of it. I treat it nice and it is great in the snow. I wont get much more then 10k$ in trade in.
I just need some boost in confidence and not to worry about it.
Thanks for reading.
Jake
50k new tires
55k new battery
Thanks for reading.
Jake
