maniac_3_2000
- September 4, 2007
- 1996 Explorer limited 5.0
I have a 1991 ford explorer with rear abs. I have been having trouble getting it to bleed because the guy before me left the brake hose off on one of the front wheels, and allowed water to get in the system. I have been able to verify that the abs hydralic unit was rusted shut. Before I replaced it I couldn't get fluid to go past that point. This past weekend I replaced the unit and got fluid to get to the rears, using a vaccum pump, at the lines right before the wheel cylinders. I was not able to pull fluid through the wheel cylinders, so I replaced those. After being able to get fluid through the wheel cylinders using the hand vaccum pump, I still got no brake action (I did also bleed the fronts which I have had no problem bleeding, with the vaccum pump, or with an assistant on the brake pedal. So after all this I tried bleeding the rears with an assistant on the brake pedal, and all I could get to come out each time I opened it, was a few drips. It's alsmost like the master cylinder isn't pushing fluid to the rears.
I have bleed the master cylinder on a bench, and both the front and rear ports pushed fluid through fine and had no trouble bleeding it, so it doesn't make since to me.
One thing I dont know is, I was told when installing the new hydralic unit, to bleed the system before installing the wiring harness to it, or the computer would detect air, or low pressure, and close the valves on me, but I dont know if that's true. I am wondering if I need to install the harness so that maybe it well open it all the way or something so that I can bleed it. I am about to purchase a pressure brake bleeder that installs on the cap of the master cylinder and bleed all 4 wheels that way, That way if I can get good flow in the rear, the only thing it could be is the master cylinder then. But before I spend 50 dollars on this tool, if anyone could give me input I would greatly appreciate it.
