wolfdadg
- April 29, 2008
- Holley, NY
- 1998 Explorer XLT
Hello all
- I am at my wits end with this truck. my problem is -- there is about 1/8 th to 1/4 in play in the rear pasenger side hub ( in/out ). Disassembled the rear pumpkin to check to see if gears were bad, they seem to be fine. I have already replaced BOTH sides of the 1/2 shafts. Could it be the shims inside the rear end them selves?? it seems that if i put pressure on the shims with a screw driver the slop dissapears, remove the pressure the slop comes back. I am able to by these shims after market or must I go to a dealer? ALSO -- would the rear end of a 1994 ford aerostar be compatable with the rear end of my 1998 ford explorer?? --- please help if you can -- thanks all
--- DYNAMITE in the gas tank is sounding better and better - for this lovely EXPLODER
