2003EB
- October 25, 2005
- New Ringgold, PA
- 2003 Eddie Bauer
Hello Peoples,
I have a 2003 Eddie Bauer 4x4 - 4.6L - 5spd Auto with about 59,000 mile on it. About a week ago I started hearing an occasional clicking noise coming from the passenger side, the noise is intermittent and might occur for 2 to 5 seconds before going away. I removed the passenger side front and rear wheels to check for something stuck in there and found nothing so today I put it up on ramps to check the U joint and it was solid and then I noticed oil on the rear end, not a ton but easily enough to know it wasn't normal. After grabbing a flashlight I discovered that the leak was at the passenger rear half shaft. I can guess that the axle seal is bad. What else may I be looking at?
Thanks,
Tim
Thanks,
Tim
