Rear Coil Spring Swap | Page 3 | Ford Explorer Forums
I get "forbidden" -- is it cauz i dont have a red star? I are the newblet.
Doesn't work for me either and i have a useless red star.
edit:used firefox and now it opens.
look back at my post I edited it and rehosted the pictures in my own album, so every one can see them.
i like the truss....
true very true
why dont you just run a panhard bar like all the old ford front suspention set ups
Because if a rig had a panhard on both the front and the back, once off camber with the side with the frame mount on the high side, then the body has leaned way over to the opposite side. Of course this is dependant on the setup and how much travel the suspension is allowed.
Run the panhard on the opposite side of the front. No steering so it doesnt matter which side its on.
Doesnt running the panhard on the opposite side have a weird chassis effect during off-camber situations?
I dunno, but it makes a wallowing effect on highway (if its a street driven rig).
run it like all the new durangos run theres. and i believe the tahoes have the same set up.
I havent seen the latest generation Tahoe but the previous generation I think runs a parallel 4 link with a panhard.
so why couldnt you use that setup. also have you thought about running straight uppers and triangulate ur lowers
hehe - how do you think you're going to attach the lower links to the centered differential with the pinion/driveshaft in the way? Keep in mind that the upper and lower links must be at LEAST 7 inches apart verticall from each other, preferably more.
when poly performance built wayne statics bronco thats what they did. they mounted the lowers out by the tires and the to the trans mount up front. and ran the uppers from the transmount tight up again the dif housing
so guess i have to check this thread more often.. anyways going to swap fuel tanks screw it BII it is. my upper rear mounts may come off the front of a geo tracker.. geo tracker weight = same rear explorer. and its the right size.. and will fit the frame great.. dont ask.
