Did I miss a post, or shouldn't we advise the OP to get the balljoints greased if they have the fittings on them? The boots being good suggests newer joints which likely can be greased instead of with spray products to find the culprit.
No grease fittings, they are original Oem ball joints I believe, I have 287,000 and purchased from original purchaser at 125 000, it is possible that the ball joints were replaced since the original owner had a lot of Maintenance performed? Doubtful...
It's probably about time for it all to get replaced here at some point. It's just one of those things, too old and not worth it to replace it all, so just fix it as it breaks...
I say this having just spent thousands on things that never broke, but just to maintain. like shocks, brakes, aluminum thermostat housing, brakes, engine gasket overhaul, muffler, fuel injector cleaning and on and on,, Now the rear end, filler neck and end links up front.
Was going to replace my endlinks on the rear as well eventually. Would everyone recommend this, the install appears simple....can't find rear sway bushings on rock for the rear oddly enough..
I also just got new fuel filler neck, how likely is it that the rubber hose is done as well? It looks bad and I'm sure clamps won't come off.
Hoping my fuel pump and timing chain continue to party on Through the winter.
Thanks everyone for the replys as well.
