kitra
- August 9, 2009
- Beaverton, Oregon
- 1999 Montaineer
I've been reading other posts and the shop manual regarding replacing the pinion seal. It looks like I need a dial-type torque meter (0-30 inch pounds?) to set the bearing pre-load. And a flat piece of steel to hold the yoke while I attempt to loosen the pinion nut. I've done all the work on our Mountaineer but am thinking I don't want to buy a $200 inch pound wrench to do the job. Also don't know what size the pinion nut is? Are there alternate ways to get the bearing pre-load correct? I've had bad luck at the Ford Dealers but am consindering giving them another try. Of course if they got the pre-load wrong and the pinion bearings melt down, they'd say "oh, the rear-end was already bad" - we didn't do anything wrong. Suggestions? Thanks
