rear end sag advice.... | Ford Explorer Forums
spotted dogs
merritt, bc, canada
98 ltd 4.0 sohc
What is the simplest way/cost effective to reduce the rear end sag I am starting to get with even the slightest load. I don't know if it's my imagination or not either, but it looks like I am getting a bit of sag without any load as well.
I would prefer a "do it yourself" option.
thanks!
A single add-a-leaf will do the trick. They are cheap and not terribly hard to do at home.
add-a-lift?
any products you would recommend or should I go see the dealer?
Um my advice? Search! all that add a leaf info or shackle info is out there
Explorer pro-comp around 35.00's
Skyjacker a little higher, around 60.00's
I just insalled the explorer add a leaf, and it was an easy install, both can be purchased from 4wheelparts.
There number is 1-800-421-1050
If you hurry, 4wheelparts.com has free shipping right now.
