When I'm driving slow like thru a parking lot I can hear a ticking noise. Any ideas?
Rotational ticking? Does the sound change with speed? If so, and the wheel bearings are OK, start by checking u-joints
and ALL brakes. Pebble stuck in a brake dust shield? Had a similar noise and ended up being a sticking rear brake caliper. :scratch:
Agreed ^ Could also be the parking brake shoes, they ride inside the hub of the brake rotor( behind the axle shaft hub/flange). There could be rust build up in there or the shoes could be starting to come apart. Something else to check.
