mysticclam
Typo King
- April 2, 2004
- Tacoma, WA
- 91 XLT
The ring gear bolts on my 8.8 backed out after less than 700 miles since installing some 4.56s One of them was hit by something which slammed it into the diff cover and cracked it. I only noticed when i came out to my truck at lunch and noticed oil dots all over the back of the truck. Took it to a shop because I thought the cover was just leaking and they showed me what happened. They are of the opinion that whoever set it up over or under tightened the bolts. It was a friend of a co-workers boyfriend who did it for cash (he races mustangs and has apparently done a lot of 8.8s) I didnt get it fixed because they said if it need a new ring and pinion it would be 1400 bucks which seems excessive. They thought maybe they could just tap the threads and use new bolts and not have to set it up but I didnt like the sound of that. I talked to the guy who set it up and he says "I remember doing it right" and that its broken because I "MUST" have put it in 4wd with the 3.73s still in the front. Yeah, in tacoma on the street I used 4wd. I disconnected the 4wd computer and verified it wouldnt go in BEFORE I took it to him anyway. It was a cash deal so I don't even have any proof he did it so I dont have any recourse.
So, if everything looks ok, which the shop said it did (other than the one ring gear bolt stripping some threads when it got ripped the last bit out) what would be the saftey risks of just retapping the one and retorqueing them all? I worry about it happening again and taking out a c clip or something on the highway.
PS, the gears have never made any noise either so I assume they were otherwise setup correct. If the cover hadnt cracked Id probably still be driving it.
