Rear Passenger Window Inop | Ford Explorer Forums
fordDC
DC
2002 XLT
Hey everyone,
I bought a 2002 XLT today. It had a lot of small issues that I've been working out, one was with the keyfob and I found a great thread on this site and fixed it in 20 seconds!
This one might be a little harder. The left passenger window is completley inoperable. There is no power control from the drivers side or the rear. And when I drive the window actually comes down like half way. the only way I get it back up is by manually pulling it back into place. Is this something that I might be able to fix on my own? or do I need to take it to the shop? thanks for any advice
Sounds like it's the window regulator. If I remember correctly it is cable driven....maybe someone else can verify this. If it is the cable probably broke.
fyrfyter612 is right it is cable driven and
they are pretty easy to remove and install
thanks for the response.. do you know how this can be done? is there any threads or any thing in specific I should search to find step by step directions? thanks
ok.. i looked into it and I need a window switch for the dirvers side rear window, the switch for the drivers control and the regulator.. id like to buy the switches used.. anyone know where I can find this? thanks
