steadyhand
- May 5, 2010
- Missouri
- 99 Mercury Mountaineer
My 99 Mountaineer RWD, auto, 5.0 has a thump sound from the rear. It only occurs when the car is in gear and I am letting off the brake. It doesn't occur when putting it in gear, just when starting to roll. It never happens once I am moving either. It can be repeated simply by coming to a complete stop and starting again.
I took a look at the brakes and all up under the rear. The only part I found that seems to be a little loose is that small shock on the passenger side.
What is the exact part name for this small shock? I asked my local parts store and they couldn't find it. It may be listed under a different part name maybe?
I can grab that small shock and when I try to twist it, it will move a little and could cause a small tap noise. I really don't think that is what's causing this thump noise which I hear very clearly in the cab. However, it is a easy start and I don't want to get into something more difficult without ruling it out.
Can it be removed, just for the sake of seeing if the noise quits or will it effect handling?
