Rear Sway Bar Links? | Ford Explorer Forums
Produce Man
san diego ca
1999 ford eddie bauer 4.0
Every post I've seen on replacing these makes no mention of weather or not the Ex needs to be raised. Can it be done w/wheels on the ground???
No lifting needed, just drop the spare tire for room. Good time to flip the tire over so the valve stem is always accessible.
Actually raising ONE wheel it will make it a much harder (impossible) job, because the bar will be under torsion.
If you need more space under, drive it on ramps.
